Extracting interpolated Y values from a multiplot cursor on an XY graph
I am using an XY Graph with multiple plots that do not always share the same X values.   I am using one cursor in multiplot mode which is associated with all plots and set to watch all plots.  In the cursor legend, LabVIEW interpolates the Y values for points that do not fall exactly at the cursor's X position and places them in parenthesis.  Is it possible to extract these interpolated numbers programmatically?  Also, dragging the cursor leaves ghosts.  Is there a setting that I have missed?
(4,381 Views)
What is your LabVIEW version? Would you mind attaching your example VI?
(4,376 Views)
Thanks!
You can easily interpolate linearly with LabVIEW 8.20, see attached. You get the same values as in the cursor legend.
The ghosting occurs here too, looks like a redraw bug.
Message Edited by altenbach on 10-27-2006 11:25 AM
(4,372 Views)
Hey Ya'll,
Thanks for the fine work you've done. This was reported to R&D (CAR ID: 4308H0LG) for further investigation.We appreciate your feedback! Thanks again.
Chris C
(4,330 Views)
