Shouldn't switch channels
Hi, I have a NI USB-6009 to analyze voltage on LabView 7.1 and I need 8 channels. The program is almost finished; the only problem is that when I read the .bin file somehow it’s switching the channels. It should be showing from ai0 to ai7, but it’s showing ai6, ai7, ai0, ai1, ai2, ai3, ai4, ai5. I know it because the rms values are wrong. I don’t know if the problem is when I write or when I read.
I need to write at i16 type, but I couldn’t make it write correctly and show the rms values at the same time, that’s why I had to read it twice at Write.vi!
Just one more thing, the date and time are not showing on the graphic, can you help me with that too?
Thanks a lot!
(2,676 Views)
You don't need to write I16 data. You can modify the VI to write U16 just by changing the data representation. Make the changes and save it with a new name in a new location. Even easier is to change DAQmx Read to return I16. All that takes is a right click (Select Type>Analog>Unscaled>2D I16) or click on the Polymorphic VI Selector below the function. Then you don't do the conversion from u16 to I16. You also don't need to do the Transpose 2D Array.
(2,641 Views)
