Extract names and tables from HTML file
In the attached VI, I would like to know how to go about extracting the 3 tables that present in the HTML file.
Thanks!
Message 1 of 8
(5,250 Views)
In the attached VI that was found on the LAVA website to extract a 2D array from an HTML file, I am not able to grab the header information.  Can you assist me in getting the header row information also?
Thanks!
Message 2 of 8
(5,265 Views)
Apparently the <b> messed up the filter for getting the inner part of the cel of the Header. I assume you are not interested in the <b> or </b> in your header tekst , and removed them.
Floris Reinders
Senior Project Engineer / CLA
Message 3 of 8
(5,219 Views)
I don't understand, you are laready extracting one... why not just continue till you extracted all?
Benoit
Message 4 of 8
(5,183 Views)
Hi hiNI,
is there a reason to create 3 threads for the same problem?
Message 5 of 8
(5,174 Views)
Accepted by topic author hiNI
Search the text for "<table" continue to "</table", repeat until you've scanned all text.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 8
(5,169 Views)
From the code provided, do you delete the first table and then run this VI again?
I am not sure how to implement the "<table" to "</table" iteratively.  Can you offer some more guidance?
Thanks.
Message 7 of 8
(5,138 Views)
Each thread asks a different question although each question stems from the same code.
Thanks.
Message 8 of 8
(5,136 Views)
