Extract color pane error
Good Morning,
I want to perform grayscale morphological transformation on images saved in a folder. When I tried to execute the program I encountered the following error.
Error -1074396080 occurred at IMAQ Extract Single Color Plane.
Possible reason(s):
IMAQ Vision: Invalid image type.
Can anybody help me what is the cause of the error.
Thank you for your help.
Message 1 of 13
(4,836 Views)
2011 compatible VI please
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 13
(4,833 Views)
Thank you for your response.
I have attached the 2011 version of the program.
Message 3 of 13
(4,828 Views)
Your subVI "DilateErode_Edge2012" is missing. Obviously, this subVI loads the image, so an fundamental part for support is not shown....
PS: Maybe you only have to connect the image(space) you created to the missing subVI....
Norbert
Norbert
Expert: Geometry
Message 4 of 13
(4,809 Views)
I have attached the missing subvi in 2011 version
Message 5 of 13
(4,805 Views)
Hm, there are some weird points in your top-level VI. Nevertheless: How does the "Edges" output from DilateErode_Edge VI look like? Is it a proper image?
Norbert
Norbert
Expert: Geometry
Message 6 of 13
(4,803 Views)
dont have LV opener right now but the error is stating that the type of the image is incorrect.  you should have a RGB (or HSL) 32 bit original image and place it into a 8bit image for the color plane, are you doing this?
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 7 of 13
(4,799 Views)
One side note: Using IMAQdx for my laptop webcam works correctly when executing the DilateErode_Edge VI only.
So i guess the camera you are using is creating invalid images (empty?).
Norbert
Norbert
Expert: Geometry
Message 8 of 13
(4,795 Views)
Please check the link.I am using the program given in that link as part of my processing.instead of acquiring image I want to give the input images that are saved in a folder ,process them using the "dilate erode " technique and save the obtained output image to another folder.
https://decibel.ni.com/content/docs/DOC-24921
Message 9 of 13
(4,793 Views)
That is exactly your subVI DilateErode_Edge....and it runs properly on my system. Does it work on your system?
Norbert
Norbert
Expert: Geometry
Message 10 of 13
(4,789 Views)
