Extract VI from its EXE
Is there anyway to extract the VI from its EXE???
Please let me know if you have any comment on this.
Sathish.
Message 1 of 8
(5,039 Views)
Hi Sathish,
it depends on the LV version and what you want to have. Smiley Wink
Before LV8 an exe was just a renamed llb-file (more or less), that was containing all vis needed for the exe. BUT: all vis had their block diagram stripped... So atleast you can look at the frontpanel.
This has changed since then, so for LV8+: NO.
Message 2 of 8
(5,035 Views)
Have you tried a search? This question has been asked many times before. The short answer: no. If you want the long answer... search. Smiley Wink
Message 3 of 8
(5,033 Views)
Sathish.
The official answer is "NO".
Tell us more about your situation and maybe we can be of assistance.
Ben
Message 4 of 8
(5,030 Views)
Thank you all for your interset on helping me 🙂
I have lost my VIs and having only the EXE in another PC. Now needs to update few thing in that EXE.
The EXE has been built in LV8.5.
Sathish
Message 5 of 8
(5,022 Views)
Then you will need to go to a backup. You have backups right? If you don't, then consider this a hard lesson learned. Smiley Wink
Message 6 of 8
(5,019 Views)
smercurio_fc wrote:
[...] You have backups right? If you don't, then consider this a hard lesson learned. Smiley Wink
And another lesson for using Source Code Controleven when working as a "lone wolf" 😉
Norbert
Norbert
Expert: Geometry
Message 7 of 8
(5,013 Views)
Thanks. I understood 😞
Message 8 of 8
(4,967 Views)
