Extract LabVIEW RT version installed on a system.
 I am trying to figure it out the different LabVIEW RTE versions installed on my PC. But not using NI MAX or programmatically using any LabVIEW VI. On search, i came to know about lvrt.dll, which has methods to display LVRTE versions. When I am trying to add this lvrt.dll in my C# .NET project assemblies, this makes Visual studio unstable and crashing. I want to extract this RTE version info through C# application. Any idea how i can implement this?
Attached screenshot.
Thanx
(5,142 Views)
Did you look at this this Knowledge Base article?  When I followed its suggestions, and hovered my mouse over a lvrt.dll file, I found the following popped up ...
Did you try this?
(4,974 Views)
Hi Bob,
Yes. I tried this. But this is just for information only. Well, my purpose is to get this information with a kind of DLL file (Possibly through lvrt.dll) which i can import to my c sharp application and get details about how many different versions of LabVIEW Runtime(s) engines installed on my system.
FYI, Other than NI MAX, If you have seen in the NI TESTSTAND, When you select LabVIEW Runtime engine in the Adapter-->Configuration settings, You can see a drop-down menu which gives you a list of all the LV Runtime version installed. This what exactly i want in my custom C sharp application which can be done with any Activex dll.... Any idea?
Thanks!
(4,902 Views)
I believe this is a Windows function, possibly .NET.  You already know that the files you need to find are those in the folder (for 32-bit LabVIEW) C:\Program Files (x86)\National Instruments\Shared\LabVIEW Run-Time\<LV Version>, and that they are named lvrt.dll.  Go find one of these folders, right-click and look at its Properties -- Windows will show you the same information I posted in my earlier reply.  At one point, I wrote VI that used .NET calls to pull up these data, so I'm sure you can find these calls on the Web, and have them work just fine in C#.
(4,858 Views)
Hello Bob,
Thanks for providing valuable information. Well, I am still working on finding other ways to extract the installed software details more likely to implement using .net core. I will share the details as I make further progress. I'll keep you posted. 🙂
(4,101 Views)
Try a Web Search using "get dll file version c#".  You know (much better than I) what information you need, and how to call C# -- this search seems (to me) to return suggestions that might be exactly what you require.  Let us know how it turns out -- others might well be interested in the Solution (and how to find it).
(4,093 Views)
