‎02-11-2016 06:34 PM
I am using the LabVIEW JTAG library that I found on this site along with a PXIe-6535. I can now get the ID from my device, but the data is five channels of waveform data. One channel is a clock, and the other four channels are data. I'm really only interested in the TDO channel. I would like to convert the data from waveform data to the actual data. Right now I convert the data to arrays of booleans, and then loop through the clock array until I see a rising edge, then I check the data array to see what the value is. It works fine, but I just can't help but feel there is a better way to do this. I looked through the waveform functions, and didn't see anything..
Does anyone have a suggestions on how to more efficiently extract the data from a group of waveforms like those described?
‎02-12-2016 12:50 AM
‎02-12-2016 01:01 AM
Hi Jo-Jo,
It would help to see your VI before giving recommendations on improvements…
@Hatef:
How does converting an array of waveforms to DDT wires makes anything "more efficient"?
Please explain why you suggested to use an ExpressVI here…
‎02-12-2016 01:30 AM - edited ‎02-12-2016 01:59 AM
Gerdw
as I told before they may help you so they may not too 🙂
but How does converting an array of waveforms
when you select Convert to Dynamic Data Express VI it let to select type of your waveform you can select 2d array of scalar and after that you can marge them easily so with just two vi may you could solve the problem isn't true ?
‎02-12-2016 02:34 AM
‎02-12-2016 02:51 AM
‎02-12-2016 12:36 PM
Here is what I am currently using. It works fine, but it isn't seem very elegant:
If it isn't obvious from looking at it, what I am doing is sampling channel 0 (data), when channel 4 (clock) transitions from low to high.
‎02-15-2016 05:35 PM
Hi Jo-Jo,
If you know which index the clock signal is located, I would think you could check the clock signal for that edge, and then index your channel signal for the value corresponding to the rising edge. It sounds like this is what you're doing, so although it is not elegant, it is effective.
‎03-08-2016 10:28 AM
The 6535 has change detection as a feature. Change your sample mode to change detect on the clock line, which will only sample the data lines in your task when a change is detected on the data line. This will remove any need for SW processing of the data afterwards and only return data as your clock strobes. May be worth testing to see if it gives you the desired behavior you are looking for in your application.
