08-06-2020 01:37 PM
@altenbach wrote:
@mikeOLU wrote:
What do I use in replacement for the dynamic data sections. I had to use them because I used one create channel vi to read all my 26 channels.
You have mostly orange, then merge and split via dynamic data. Most likely "built array" and "index array" will to exactly the same thing.
Dynamic data is very dangerous because they can contain a wide variety of data types and there is no way to tell by looking at the wire.
@mikeOLU wrote:
I think I can remove the time array local variables, however, in the two inner loops I have, I don't know how I can use the loops without using local variables, any suggestion on that will be appreciated.
Can you point to the "inner loops"? I can't find them. I only see a single loop. Did you attach the correct VI?
Build array and index array are doing the jobs of split and merge. I appreciate your response.
08-06-2020 03:13 PM
@mikeOLU wrote:
Do you mind uploading the VI you just updated? and any suggestion on replacing my dynamic data may be included too. Thanks.
That was just a very local cosmetic edit. There is no modified VI. Good luck!
