Exporting image from an intensity plot
For simple waveform charts, it is possible to export an image through Right Click >Invoke Node > Export Image.
However, there is no such option for intensity plots. How does one produce an image from intensity plots ?
(3,657 Views)
Right-click -> Create -> Invoke Node -> Get Image. Wire the "Get Image" output "Image Data" to the Write JPEG File.vi (Programming -> Graphics and Sound -> Graphics Formats palette) input.
Other than JPEG formats also possible.
While evaluating my code please have in mind that I am a LV novice. Therefore sometimes my code might violate some coding rules that I have to learn about myself. But how else could I do that... 🙂
Chart zoom with "Mouse Over" effect
(3,650 Views)
Thanks.
You probably solved another problem of mine. The Export to Image function generates bmp images, which are very large. Jpeg is a better format.
(3,637 Views)
Why so?You can choose the type of the file.
Why is the previous suggestion unacceptable for "this" problem to be solved?  Maybe I still will be able to help.
(3,635 Views)
