Export to Excell
I have a problem when i try update a excel sheet because array which i export, adds 3 zeros to the values of every cell such as shows in next figure..
(4,069 Views)
Your screenshot misses line 2 of the array, so we cannot see the make up of the numbers there. I assume that the second line is the same as the first, but you should confirm that.
It looks like a localization issue to. If your localized OS uses ',' instead of '.' as decimal symbol, it is possible that issues like this occur. Please check your regional settings in the OS.
hope this helps,
Norbert
Norbert
Expert: Geometry
(4,060 Views)
line 2 of the array is empty:
Localization can't be the cause because in every cells there are 3 more zeros without "," or ".".
Also, on another sheet values are exported correctly
 Best regards
(4,029 Views)
Hm, i am not convinced that it is NOT an ./,-issue.
You have to keep in mind that at least in the US, the '.' is the decimal point where as the ',' seperates "thousands".
E.g. 1M writes as double:
1,000,000.00
Norbert
Norbert
Expert: Geometry
(4,022 Views)
Ok, i know...but. why adds zeros when reads from excel sheet??? and not in the other way (when writes values)
I did other test: resumen 2D divides by 1000 previously
This is the result :
 Doesn't divide all the cells....
very grafetul
(4,003 Views)
Please post your VI and your .xls file.  Then we can play with it and see what it going on.
(3,995 Views)
Accepted by Squal
I found the solution: needed to be configured format string parameter in Append Table to Report.VI
Thanks you very much to all
(3,987 Views)
