Export from Microsoft Access Database to Excel
Then read the Help file for MS Access. It tells you how to do it.
Message 11 of 14
(1,236 Views)
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 14
(1,224 Views)
hai yamaeda
  i tried by pasting my query in access and came out with few more doubts
SELECT Serial_Number,System_Date,System_Time,Department,Operator_Name,Serial_Number,Test_Case,Pass_Fail FROM TEST_REPORT  where System_Date = "4-16-2012";
when i pass the above query directly in access i could exactly what i need but an error in labview stating that it contains invalid string. " ; are the invalid strings i guess,is there any way to pass them?
Message 13 of 14
(1,209 Views)
Accepted by Sumithra_Nagappan
Hai
I fixed the issue with htis link https://decibel.ni.com/content/docs/DOC-10091. Use of sql statement generated ,it is easy to fetch/sort data as per our requirement.
Message 14 of 14
(1,180 Views)
