Exponential String to Number
Sitank wrote:
Thanks for the help, but am done with my issue... 😄
So, what was the problem?
Message 11 of 13
(1,207 Views)
Nothing, I just changed my program a little, instead of using VISA read, I used the instrument driver specified interfaces. And, it worked. But sticking to the old program I didn't work on it, may be will see to it later.
Message 12 of 13
(1,178 Views)
May be this is usefull for the ones that don't whant to change their programs, is very easy.
I had the same(or very similar) problem so i read all the posts. If i understood what was the issue the solution is very simple you have to use "fract/exp string to number function" and if the decimal separation is a point you have to add a boolean as false in the "use system decimal point" and that solve the issue.
Message 13 of 13
(1,131 Views)
