Expand a Excel-File
Hello everybody,
I want to expand an Excel-File. I want to open it and write data in a new line line.
I want to do some measurements and write the gotten data to the Excel-file.
Every measur-data should get its own line. Is that possible. I didn´t find any example in the example finder.
Could somebody help me please dealing this.
With kind regards
Daniel
(3,503 Views)
Is this an actual Excel workbook, or a text file that's formatted so that it can be opened in Excel? Big difference. If you have a text file are you using the "Write to Spreadsheet File" VI? That has an "append to file" input.
(3,497 Views)
Thanks smercurio… for your fast reply,
I should only be able able to open it with excel, therefore it needn´t to a Excel workbook. I´ve only searched in the Report Generation Toolkit Examples, that was my fault.
With kind regards Daniel
(3,490 Views)
OK, so you're using the Report Generation Toolkit. Unfortunately, I don't have that toolkit so I'm afraid I won't be able to provide any more input.
(3,482 Views)
If you are using the Report Generation Toolkit go to http://zone.ni.com/devzone/cda/tut/p/id/3178 . This is a pretty good tutorial on how to use it. You might be particularly interested in the design 4 Excel Insert Cells function.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,470 Views)
Thank you so much for the link.
I am only interested in write my data in a new line to an excisting excel- or a compatible file.
I don´t need to formate this cells.
With kind regards
Daniel
(3,452 Views)
