Execute library call on remote computer
Hi all,
Is it possible to have a Library Function call to be executed on a remote machine ?
I have a PC in my lab that is connected (via USB) to some measuring device which comes with a DLL. Now I would like to run a VI (on another PC, eg. in my office), that calls functions from that DLL that communicate with the device. Therefore, the DLL-function call has to execute on the lab-PC, not on the PC where the VI runs (my office PC).
Is this possible, and how would I do it ? Thanks for any advice
Best regards, DeSa
Message 1 of 9
(3,480 Views)
De_Sa,
You can use VI server to open a VI reference on your Lab PC. You can then run the VI on that machine, which would house your DLL. Please let me know if I need to elaborate.
Prashanth N
Message 2 of 9
(3,473 Views)
Hi Pachi,
sounds interesting. Unfortunately my remote machine has no LabVIEW (only the VISA server is running) and I only have the Base Development System.Or did I misunderstand you ??
DeSa
Message 3 of 9
(3,471 Views)
Desa,
In that case there are alternatives, You don't necesaarily have LabVIEW on your target.
It is sufficient to have LV Runtime on it. You could deploy your application on it.
Prashanth N
Message 4 of 9
(3,468 Views)
I'm relative new to LabVIEW and have never deployed a VI. Do I use the Web Publishing tool, or is there a good Tutorial on how to deploy the vi ?
Thanks, DeSa
Message 5 of 9
(3,463 Views)
DeSa,
You could use the Application Builder to build a *.exe application. You can then run this exe on your target.
However, you might need LabVIEW Runtime on your target to execute it.
Prashanth N
Message 6 of 9
(3,461 Views)
Unfortunately I don't have a license to use the application builder... Are there other options ?
Message 7 of 9
(3,459 Views)
This should help you out
http://zone.ni.com/devzone/cda/tut/p/id/3303
Prashanth N
Message 8 of 9
(3,458 Views)
You could try to call the DLL directly from the target without using LabVIEW. If you use LabVIEW, you will need one of these two options to distribute it,
Prashanth N
Message 9 of 9
(3,456 Views)
