Execute VI in certain hours
I want my VI to start (for example) at 9:00AM to 5:00PM (This hours should be customizable), when we are into this time slot I want to set a boolean at the value true.
Any example please ?
Thanks;
Peter
Peter.
Labview 2010
Message 1 of 12
(3,514 Views)
In labview examples at the website:
Run a task that starts at a start time and stops at a stop time.
https://decibel.ni.com/content/docs/DOC-4521
Message 2 of 12
(3,513 Views)
Why don't you just use the OS scheduling capabilities? Seems to me to be far easier.
Message 3 of 12
(3,509 Views)
Hi EmcV,
the solution that you gave to me is not exactly what I want, in fact my VI should be executed between 9:00 AM and 5:00 PM "every day" and your in your example it isn't that. How can I modify it to do what I want ?
Peter.
Labview 2010
Message 4 of 12
(3,507 Views)
So what is your problem with the windows scheduler solution that was given? Unless your VI is always running, you'll need another program to start it.
Message 5 of 12
(3,493 Views)
Yes my VI is always running ...
Peter.
Labview 2010
Message 6 of 12
(3,491 Views)
Well, if your VI is always running, then what is the issue with the simple approach shown in the linked article? All you need to do is look at the current time and compare it to the set time, or a pair of set times if it has to run only between certain hours.
Message 7 of 12
(3,486 Views)
So then, I don't understand what your problem is. Doing a time comparison is pretty simple as the example shows. Attach your code with details on what does not work.
Message 8 of 12
(3,483 Views)
For example:
To remove date just convert to number which just contains time string.
Probably there are more beautiful ways
Message 9 of 12
(3,480 Views)
the problem with your example is that my program is always running and must do task in a  time slot every day.
EmcV you probably have the right solution : remove the date. Can you resend your VI example for the labview 9.0 version please.
Peter.
Labview 2010
Message 10 of 12
(3,478 Views)
