Executable with DFD toolkit
Just a quickie but if I build a an application containing a DFD vi will I be able to run the application successfully on a pc running only the LabVIEW run time engine?
Strokes?
(2,539 Views)
See this link:-
http://forums.ni.com/t5/LabVIEW/Labview-created-DLL-which-uses-Labview-built-in-VIs-from-the/m-p/140...
Thanks as kudos only:)
(2,534 Views)
