‎01-16-2007 01:58 AM
‎01-16-2007 03:10 AM
Not that I have any experience with NI vision, but do you have the LabVIEW RTE insalled?
Also, what are the exact problems with the application?
‎01-16-2007 03:41 AM
‎01-16-2007 06:00 AM
In LV versions before 8, there is a Source Files tab in which you can add files to your build. If you want this to work with the installation, you then need to go into the Installer tab and specify where your support files will go relative to the executable.
I don't know how it's done in 8.x, but I expect that it's not much different.
