Excutable running error
I'm having an issue getting an error on one particular executable loading and running correctly.  I have created the executable with no issues and gotten it to load and run fine on other computers.
On the computer in question, I am getting an Error code 3.  Apparently it isn't loading a vi ("Could not load front panel" according tot he message.).
Is there a somewhat easy solution to fix this?  I can't seem to find a way to fix the problem.  As I said, this works fine on other computers, but there is a problem with this particular one.  The updated Run-Time engine is installed.  It is a Windows 7 system.  The computers where the program works fine have regular Labview 2010 installed.  I'm not sure if that makes a difference.  However, I have created the same executable and deployed it on a machine without regular LV, and it ran fine.  I just honestly do not know why this time it cannot work properly.
Any suggestions would be helpful.
Thanks in advance.
Using Labview 7.0 and 2010 SP1 with Windows XP and 7.
(2,627 Views)
Is this executable being built on a 64-bit machine and run on a 32-bit machine by any chance?
(2,609 Views)
