Exclude a iteration
Hi.
I have to exclude a value from an forloop, and i don't how to do..
I've done an example of what I want to do on the vi that i have join
Explication :
when the iteration 5 appears, we go directly to the value 6 without take care about what we are supposed to do for the value 5.
Peter.
Labview 2010
Message 1 of 11
(4,915 Views)
Hi Peter,
maybe you need to use a shift register as shown in the attachment?
Message 2 of 11
(4,911 Views)
Thanks for your answer.
In this solution it duplicate the iteration #6 . And I just want one opération by iteration. Smiley Sad
Peter.
Labview 2010
Message 3 of 11
(4,907 Views)
If your need only to remove an element from array, it is better to use delete from array
If you plan to add more actions on array elements and want to skip an iteration, then you need to do nothing on "skipped" iteration. Autoindexing does not have "Disable terminal" to skip it, so number of your elements will not change - it does not suit you.
Message 4 of 11
(4,898 Views)
Sorry my vi's example seems to be not clear, so I join you the original VI;
In fact, the problem come from this part of the VI
The SubVi has some parameters whose one is the adress of the device. The device at the adress 6 is missing, so I don't want to call him thus skip the iteration #6.
Peter.
Labview 2010
Message 5 of 11
(4,891 Views)
Place a case inside the loop which does nothing if the loop i is 6, defaul the current code.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 11
(4,887 Views)
What should I put in the case ? Sorry I'm a notice on Labview
Peter.
Labview 2010
Message 7 of 11
(4,883 Views)
If you want to go with your code, you need to reduce the iteration count by one and change the "=5" to ">=5", else you are doing one operation twice.
Why is there a delay in the loop? Does it matter what happens in the loop or is only the output array important?
Here are some possible interpretations, assuming you want the loop with the delay. If only the output matters, used the second option and delete the loop.
Message 8 of 11
(4,882 Views)
Accepted by Peter Saraiva
Maybe like this?
Also:
  • Your lower loop consumes 100% of the CPU while doing nothing. It needs a small wait
  • Change the 8 frame sequence into a state machine.
  • etc.
Message 9 of 11
(4,880 Views)
Hi Altenbatch,
Thanks a lot of your investment .
I can't open your VIs because on this computer I have the 2009 version of Labview. I shall inform you on monday when I shall have tried it on my desktop computer
Stay in touch.
Regards.
Peter.
Labview 2010
Message 10 of 11
(4,853 Views)
