Excercise9-2. Question 2. Adding SetPulesSpec.VI
Data Acquisition & Signal Conditioning Course Manual.
I have deleted "Set Attibute.vi" every time I open the "Set Pulse Specs.vi" the panel just keeps coming up. I need to insert it as a VI?
(3,032 Views)
yes you need to add it as a vi to the block diagram. Using the select a vi palette on the block diagram navigate to the zadvdctr.llb and open it. It will then allow you to select the vi that is contained in the llb. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,032 Views)
Thanks for that. Should of know about "Select A vi..." on the function palette.
Thankyou.
(3,032 Views)
The select a vi utility in the functions palette gives you the flexibility to select a vi and recall it in the application you are building and thereby use it as a subvi.
This method is clearly used for instantiating a set of vi's the user wants to use in his application.
Best Regards
Atul Wahi
www.ni.com
(3,032 Views)
