Exception Error With Device Reset (0XAC)
I'm using 2 PXI-4472 cards (MXI-4, Ni-Daq 7.0.0f8, Labview 7.0).
Before configuring those cards, I reset them by running the Device Reset.vi (Ni Daq).
It works well, but sometimes, an exception error occured and I don't know why.
The problem is always when calling the Device Reset.vi (dialog box exception 0XAC).
Please find attached the capture of the dialog box.
Anyone know this problem or ideas ????????
Eddy DUCHENE
12 F Chemin de Boutary
69300 CALUIRE ET CUIRE
educhene@laposte.net
(2,809 Views)
Hello Educhene,
To answer your request, I need to have more information :
1 - OS?
2 - Do you have the same behavior using MAX (Measurement and Automation eXplorer)?
3 - You use the function "Device Reset.vi" in complete LV application or just alone?
4 - Have you tried to install the last version of NI-DAQ 7.3?
You can download it for free on the link below :
http://digital.ni.com/softlib.nsf/websearch/BEC182021CEB566C86256EEE00696562?opendocument&node=132060_US
If yes, have you the same behavior using DAQmx?
Waiting for your answer.
Sanaa TAZI
National Instruments France
Sanaa T.
(2,790 Views)
well, since I have installed the latest version of Ni-Daq and change my PC, it seems I have not the problem.
But I will test it more to verify the process. If I encounter it again, I will notify you.
OS : XP
Labview 7.0
Ni-Daq 7.3
Eddy DUCHENE
(2,783 Views)
