Excel template with executable file problem
Hi all, I have a template file excel(.xlsx) it works in the directory from build process but when I making the installer it looks like can not access the template file, any help please advise thank you.
(1,502 Views)
You must include Report Generation Toolkit's dynamic VIs in build specification:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019O6PSAU&l=en-US
(1,478 Views)
The default location for support files is the ..\Data folder below the application folder.  You should add this location to the relative path of the template: "..\Data\FileSupport.xlsx".
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(1,456 Views)
