Excel sheet
Dear Friends
             I have a doubt in Excel sheet.While running the LabVIEW i have to change th colour in excel sheet for each cell in LabVIEW 8.5.Please post your suggestions
Regards
JAI
Message 1 of 8
(4,775 Views)
Do you have a doubt or a question?  They are two different words with two different meanings.
KarthikeyanMathialagan wrote:
I have to change the color in excel sheet for each cell in LabVIEW 8.5.
What cells in LabVIEW are you talking about?  How are you determining which cells in the Excel sheet you want to change the color for?
You would use ActiveX methods in LabVIEW to change the properties of cells in an Excel spreadsheet.  Search the forums and you'll find numerous message threads on this.
If you need more specific help, please post your LabVIEW code that you have so far so we can see what you are trying to do.
Message 2 of 8
(4,741 Views)
Hiiii
Actually from Labview through programatically can i change the colour of the paticular cell....
Message 3 of 8
(4,703 Views)
Ya, we can programatically change the colour of particular cell.Find the attached vi.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 4 of 8
(4,694 Views)
Hello its working in Labview 8.6 boss i need in 8.5 is it possible......
Message 5 of 8
(4,689 Views)
Refer the screen shot.
Balaji PK (CLA)
Message 6 of 8
(4,684 Views)
See in my Labview 8.5 i am not having the Labview report generation toolkit... so it is not in my Function pallet.... so without this toolkit i can't edit the cell colour aa??
is there any other alternate method to do the same thing without using these VI's ... i.e by using property node.........
Message 7 of 8
(4,674 Views)
I think u can also do this using activex. Check in this library
Balaji PK (CLA)
Message 8 of 8
(4,659 Views)
