03-30-2009
02:55 AM
- last edited on
08-21-2026
09:18 AM
by
Content Cleaner
I have used this link (http://digital.ni.com/public.nsf/allkb/9CEC8B2C1E67039586256DEF006F9A0E) to plot points (instead of lines) with the polar plot demo of Labview (see attached file). Could anybody tell me if it is possible to change the size of the points on the plot (I would like them to be bigger).
Thanks a lot,
Forum_75
Solved! Go to Solution.
03-30-2009 03:16 AM - edited 03-30-2009 03:19 AM
Find the attachment (in LV8.6) to increase the size of the plot.
03-30-2009 06:52 AM
Hi Baji,
Thank you for your time and answer.
I am sorry but I can't find the place where I can change the size of the points on the plot.....Could you tell me?
Thanks a lot,
Forum_75
03-30-2009 10:17 AM
03-30-2009 11:28 PM
Yesterday, I forget to mention how to change the plot width. ya as smercurio_fc said change the pen width to increase the plotwidth,I attached the VIs have a look at it.
03-31-2009 02:33 AM
Thanks a lot to both of you for your help. It works fine. I had actually tried this before but it didn't work. I suppose at that time my Global VI was using the sub-VIs by default which where in the Labview folder and not the ones I was modifying in the folder on my desk....
Thanks again,
Forum_75
