Excel sheet modification in a program.
Hi smercurio,
I used  part of your parse.vi and used a simple spread sheet as you have suggested. It worked.
Message 11 of 14
(931 Views)
OK... Except that format isn't the same as what you mentioned in your last reply. Your last reply had
time
channel 101 channel 102channel 103 ...
as column headers. The spreadsheet you attached has something entirely different.
Message 12 of 14
(927 Views)
Hi smercurio,
Sorry, I have attached the wrong xls file. Here it is.
thanks you.
Message 13 of 14
(908 Views)
OK. That looks better.
A few tips on your VI:
  •  As I indicated before, it's pointless to always initialize and configure and close the instrument each iteration of the loop. Initialize, configure, and close outside of the loop. The only thing you need inside the loop is just the reading part.
  • The writing of the column headers for the table also does not need to be done each time through the loop.
  • You've hard-coded the writing of the first row, but you have a channel list control. So, is the channel list fixed, or is it user selectable? If it's the latter, then the first row of the output file must match what the channel selection list is. That's the point of the code that creates the column headers for the table indicator.
Message 14 of 14
(896 Views)
