Excel and .NET Problems
What am I doing wrong here?  When I select the .NET class, the only object I see is the StandardOleMarshalObject, which doesn't have a GetActiveObject method.  Maybe I need to update the .NET installation.  I haven't run Windows Update in a while because it usually breaks something.  Smiley Mad
aputman
Message 11 of 16
(2,118 Views)
Not sure what is going on. Every time I try to select it LabVIEW crashes, the VI attached should work. I will need to test later, need to go to a meeting.
mcduff
Message 12 of 16
(2,112 Views)
mcduff
I can't use your snippet because my LV2017 is installed on a VirtualBox image and I don't have Excel installed there.  So I was trying to recreate in LV2012.  I updated .NET and I still can't find the Marshal method.
aputman
Message 13 of 16
(2,102 Views)
See if this helps. Finally got it.
LabVIEW 2011 version attached, no Excel.
mcduff
Message 14 of 16
(2,096 Views)
Ah, that makes sense now.  Found it.
aputman
Message 15 of 16
(2,091 Views)
Greetings,
Any clue about opening an Excel file using .net, keep getting error 0x800A03EC when using open method in the workbooks class.
Message 16 of 16
(2,031 Views)
