How to select the appropriate library from type library for Automation Library - to use DLP Lightcrafter
I want to control dlp gui via activeX or any way i can do on labview
I tried the followings:
- putting an activex container in front panel  -> insert activex object -> create object from file -> choose gui.exe
but no methods show up in invoke node
- putting an automation refnum -> select activex class ->  browse -> select object from type library -> ...
here  there are lots of libraries which one should i select i am confused and what are those i dunno
Thanks in advance.
(2,650 Views)
Hello.
In this case you should consult the DLP community because that hardware is out of our scope, but you can try something like this.
https://e2e.ti.com/support/dlp__mems_micro-electro-mechanical_systems/advanced_light_control/f/850/t...
https://e2e.ti.com/support/dlp__mems_micro-electro-mechanical_systems/advanced_light_control/f/924/t...
Regards
(2,620 Views)
