Excel and Labview
You've been given tips in the previous messages.  Search the forums for Excel and ActiveX and also report generation toolkit.
Message 11 of 14
(1,996 Views)
Here's a suggestion -- your Excel files ("true" Excel, .xlsx) are going to be difficult for humans to understand.  If they are supposed to be (presumably sequential) commands to a Robot, what are the commands?  In other words, what do the columns represent?  I urge you to consider making Row 1 a "Label" row whose entries are (string) labels describing what the various columns represent.  You wouldn't want to put a "position coordinate" in a column that is supposed to be "joint acceleration", for example ...
Now follow RavensFan's suggestion.  Google can be your friend ...
Message 12 of 14
(1,980 Views)
Accepted by topic author Mac98
@Mac98 wrote:
do u happen to have the block diagram for me to use excel in labview?
LabVIEW comes with many example for manipulating Excel. To find the examples, go to help > find examples
Message 13 of 14
(1,959 Views)
In your recent reply saying what you wanted to do, you noted that you hoped to read Excel data (and thank you for providing a sample data file).  The Report Generation Toolkit was designed for producing a Report, i.e. for writing Excel.
But don't worry -- you can also use it to read Excel -- it is just a little more work.  New Report has an input marked "Template" -- any Excel (.xls or .xlsx) file placed here will be read.  If you have a Normal Window, you'll actually see Excel open and show you the data.
Excel Read Data is on the Excel Specific/Excel General Palette.  This function wants to read either Strings or Numerics (read its Help entry).  There's a function that will tell you how many Rows are in the Spreadsheet (provided you don't clear any rows -- it gets the Count from Excel), but there is no analogous function to tell you how many columns there are.  You may need to play a bit (what sometimes works is to read into a 2D array of strings, and use the size of the Strings to tell you how many rows and columns there are).  The Read Data function lets you specify what area of the Excel Spreadsheet you want to read, so if you have a Header Row and the rest of it is data, you can just "read the data" (in a second Read, of course).
Message 14 of 14
(1,952 Views)
