Excel Report Generation
Hi all,
           I have an issue in Excel Report generation.In my PC I have ms office 2016 version and in Remote PC 2010 version ms office .When I run executable file from my PC it is working fine.when i run in remote PC  i am getting issue with report generation issue.
How to solve this issue.
RAVITEJA S
(3,012 Views)
Hi Raviteja,
which issue do you get?
Is this "issue" related to Excel/Office or to your overuse of local variables?
(2,992 Views)
Hi GerdW
                 Issue is related to excel/office remaining entire application is working fine in my pc i am able to run the application fine.when i build the executable file in my pc and if i try to run  the builded exe  in remote pc,i am unable to generate report.In my pc microsoft office version 16 and in remote pc it is ms office 10 version.
RAVITEJA S
(2,969 Views)
Hi Raviteja,
Which error message do you get?
(2,962 Views)
Microsoft makes changes to Excel (as does NI with LabVIEW).  One change, made between Office 13 and Office 16, caused problems when saving Excel reports with LabVIEW 2016 and (I don't know if it was "fixed" in LabVIEW 2018).  Given that you changed one significant player in this two-program enterprise, and did not develop a separate version that would be backwards-compatible with code written more than 8 years ago, it is not surprising that you cannot run it on the older system.
Either upgrade the older PC's software (perhaps including its Operating System, which might not be Windows 10), or build a new LabVIEW Executable that has been designed and tested to work with the older PC.
(2,946 Views)
https://www.ni.com/en/support/documentation/compatibility/17/report-generation-toolkit-and-microsoft...
I don't know how strict these compatibility requirements are but since you seem to be having problems on one machine and not the other, I'd say you better give this chart a gander.
aputman
(2,918 Views)
