Excel Reference Issue
I have a VI Developed in LabVIEW 8.6. It has an Excel Application activeX control and Indicator in the VI. It is working fine with Excel 2003 and Excel 2010. I masscompiled the VI to LabVIEW 2010 and used the same VI. It is throwing Error as Class Not Registered. When I remove/disconnect the indicator(Dup Excel._Application), the VI works fine. But it throws error only when it has the Excel Reference Indicator connected.
When I create a new by Right-Click-->Create Indicator, the same VI works(after deleting the old Reference).
Please suggest your options.
Find the attached VI.
OS:Windows XP
Suresh
(3,874 Views)
if you use the Report generation toolkit, I suggest you to read this thread and this one.
I hope this can help you to solve this strange behaviour.
V-F
(3,862 Views)
I do not have Report Generation Tool Kit Installed.
Also I installed MS Office 2010 Recently(After 2010 LabVIEW Installation).
Suresh
(3,849 Views)
Any other Option to Check this?
Suresh Kumar.G
(3,823 Views)
