07-31-2008 09:53 AM
08-01-2008 09:53 PM
08-04-2008 03:53 AM
Hello Samuel.
With Vista, your application might be attempting to do something that requires administrative access. Either the application is attempting to write to a restricted area of the file system or registry system, or the application makes a call to an external process which requires admin access.
This KB should solve your problem.
Best Regards.
Romain D.
National Instruments France
NIDays 2010 : Conférence mondiale de l'instrumentation virtuelle
>>Détails et Inscription<<
08-04-2008 01:17 PM
08-05-2008 02:50 AM
Hello Samuel.
Could you attach a part of your code which reproduce your problem? I will try it and I let you know what I find out.
Thanks in advance.
Best Regards.
Romain D.
08-05-2008 06:43 AM - edited 08-05-2008 06:46 AM
08-05-2008 06:56 AM
04-25-2011 03:47 AM
3 years later, still the same pb with labview 2010 sp1 and win7. Are there any improvement concerning this issue?
I need my computer in my local language settings so that I dont get bothered with ",", ";" or "." when opening .csv files, dealing with numbers, time, etc... But I need to change those settings to english to be able to use .net.
Any workaround so that I can use .net constructor with my local settings?
Best Regards,
Tom.
04-26-2011 02:15 AM
Hey Woss,
Unfortunately, local languages are a bit tricky. Because Germany or France or the US or Turkey will use a coma in a different way than a dot, there can be some unexpected behaviour at some point in your programmation process. There's not much to do about it, and it's not an issue related to National Instruments or LabVIEW but to Windows and the way countries use the delimiters.
If you have any further question, don't hesitate 😉
Eric.
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
