Excel Column Header
Hello all.
I am creating 7 columns data for every itteration from for loop.
My materialnumbers isnt constant. So`its can be 10 or 3. I can write all datas to spreadsheet without headers.
I need save my datas like attachment to excel.
In this excel file headers creating automaticly.
Every for itteration i creating 1 material and 7 values (array values).
Thanks.
Kerem.
(5,808 Views)
Without one of the add-on toolkits you can not merge cells like the first row of your headers or color cells.
I believe the XLR8 add on will do that, maybe the NI MS Office Reports Toolkit  will too but I don't know.
Your second row is easy just write the headers to your file as strings once before you write any data.
=== Engineer Ambiguously ===
(5,781 Views)
Thanks for your reply.
I can do second row with MS-Office Report Tools.
But first row is problem still.
(5,750 Views)
Accepted by keremgeliz
This can be done but needs to use Invoke and property nodes to access the Excel Object Model.
Once you have a reference to the Workseet use the Range Method to define the cells to merge then use the Merge method on the Range object to merge the cells
I have also used the range property to set the value and alignment (I dont know why but -4108 centres the text) and create an interior object in order to set the colour
Result
(5,739 Views)
Unfortunately, ActiveX is no longer so well documented -- I had to struggle to get the ActiveX Help document to do anything in Windows 7 (worked much better in XP).  The Horizontal Alignment Property, according to Microsoft, can be any of the following xlHAlign constants:
   xlHAlignCenter
   xlHAlignCenterAcrossSelection
   xlHAlignDistributed
   xlHAlignFill
   xlHAlignGeneral
   xlHAlignJustify
   xlHAlignLeft
   xlHAlignRight
I couldn't get values for these.  However, I did find, on the Web, a reference for Office 2007 with values (and no explanation):
   xlHAlignCenter                           -4108
   xlHAlignCenterAcrossSelection          7
   xlHAlignDistributed                     -4117
   xlHAlignFill                                       5
   xlHAlignGeneral                                1
   xlHAlignJustify                           -4130
   xlHAlignLeft                               -4131
   xlHAlignRight                             -4152
Note that the numbers are either three-bit positive numbers or 6 bit numbers with the higher 10 bits all set (I'm assuming this is intended to be a U16 quantity).  On the other hand, it really only needs the lower six bits -- I wonder what would happen if you tried 52 instead of -4108 ...  Ahh, the wonders of Microsoft Abandonware ...
(5,719 Views)
   xlHAlignCenter
   xlHAlignDistributed
   xlHAlignFill
   xlHAlignGeneral
   xlHAlignJustify
   xlHAlignLeft
   xlHAlignRight
   xlHAlignFill                                       5
   xlHAlignGeneral                                1
   xlHAlignLeft                               -4131
   xlHAlignRight                             -4152
You can find the values here.
Ben64
(5,706 Views)
Thanks for your help.
Its seems complicated.
(5,642 Views)
