04-04-2011 05:10 PM
Estou com dificuldade em criar um VI que se comunique com o hardware, preciso fazer uma leitura de valor de tensão. Poderia me auxiliar, enviar um tutorial ou algum exemplo?
04-05-2011 02:08 AM
Portugese to English:
I'm having difficulty creating a VI that communicates with thehardware, making an accurate reading of tension values. Could youhelp me, send a tutorial or some example?
Hai,
Please post in English for more responses. What is your hardware? Where you find difficulty? Post more details and get more support.
Mathan
04-05-2011 06:26 AM
Hai,
Mathan
Sorry...
My hardware is PCI 1711 and I have a difficult with the interface between labview software and hardware.
Ana
04-05-2011 07:56 AM
Can you post any LabVIEW code you have made at this point?
Você pode postar qualquer código LabVIEW você tenha feito neste momento?
04-05-2011 09:15 AM
I don't have code.
I need read the tension value and I don't know what the code I use.
04-05-2011
09:20 AM
- last edited on
11-02-2026
03:13 PM
by
Content Cleaner
I do not know what a PCI 1711 is. It's not anywhere in the list of products that NI sells, as far as I can tell. Is this a DAQ device? If so, have you installed DAQmx? If you did, then it would have installed tons of examples. Have you opened the Example Finder (Help -> Find Examples) to look? For a starting page with DAQmx, look here: Getting Started with NI-DAQmx: Main Page- Developer Zone - National Instruments
04-05-2011 09:26 AM
04-07-2011 12:16 PM
I can't download the Advantech 32-bit LabVIEW drivers... message: the page not found... I need this driver, can you help me?
thanks
Ana
04-07-2011 12:33 PM
Not really, because that's the Advantech web site, so you will need to contact the web master there if you have a problem downloading files from their web site.
As far as putting the file on here, I don't think NI is too keen on hosting drivers from a competitor. ![]()
