Example of state-space ?
Hello;
I am a graduate student and tomorrow I have my presentation and really I need your feedback .
I have select a topic which is STATE-SPACE ANALYSIS .
The attched file has my vi file.
I have dwsign a simple leve;l control loop that has a transfer function then I have convert it to SS that I make the analysis.
Appreciate your swift response.
(3,527 Views)
You did not include any of the subVIs, so we cannot really see much. Are these from a toolkit?
(Your WHILE loop should be reaplced by a FOR loop. You can do autoindexing in the arrays to simplify the code. No index array wired to [i] needed.)
(3,511 Views)
Accepted by JIC
also try cleaning up your front panel a bit. use tab containers or make it to where the person does not have to scroll to see your items.
and use Altenbach suggestions.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,507 Views)
I see that you are using the Control Design and Simulation Module. What exactly are you trying to achieve in this VI. Have you tried looking at examples that perform state-space analysis? Please let us know some more about what you are trying to do.
Vivek Nath
Applications Engineer
Machine Vision
(3,456 Views)
