Example finder kills network connection
I strange error I'm getting, both in LV2013 and LV2014 (I'm using the evaluation versions).
Opening the labview example finder kills my network connection permanently until I reboot. Then after reboot, the network takes a minute or two to come up, which is longer than normal.
Any ideas?
(3,304 Views)
What kind of network connection do you have?
What OS?
Did this ever work?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,275 Views)
Hi Mike,
It's a new Windows7 laptop. Only had it a couple of weeks and no network problems until LabVIEW was installed. No, LabVIEW example finder has never worked on this machine. It's a wireless connection.
(3,269 Views)
When the connection goes bad is there any change in its status in the Windows wireless manager? Does your laptop have a hardware wireless enable switch? If you turn you wireless off and then back on, anything different? Have you tried this with a hardwired network connection? Does it do it with any WIFI connection?
Mike...
LabVIEW Champion
(3,262 Views)
Hi Mike,
Sorry for the delay, however I wanted to get a better idea of what was going on before posting.
I haven't tried this with a wired connection, but I have now identified the behaviour as follows:
1. Wireless freezes after 10-20 minutes of the computer being on. I don't even have to launch LabVIEW. Anything that tries to access freezes, e.g. Firefox never launches, a ping in a command window never returns etc.
2. Wireless still shows up as connected and with a signal. Running windows diagnostic on the connection shows no problem.
3. Disconnecting the wireless and reconnecting shows there is a problem- it shows as unavailable after trying to reconnect.
4. Uninstalling LabVIEW and all associated software removes the problem.
(3,190 Views)
In addition to the post above, the LabVIEW uninstall froze at various stages saying it could not uninstall various NI associated services (sorry, I forgot to write the names down). To successfully uninstall, I set all the services to 'disabled (at startup)' and rebooted.
(3,181 Views)
Well it looks like you have your problem: a bad install. If LV can't even uninstall itself, something is dramatically wrong.
Just to cover all your bases, I would run chkdsk on the drive to make sure everything is kosher, and run a utility such as ccleaner on the registry to see if it finds any problems.
Mike...
LabVIEW Champion
(3,160 Views)
