05-12-2008 01:37 PM
05-12-2008 01:51 PM
05-12-2008 02:03 PM
05-13-2008 08:57 AM
05-13-2008 09:04 AM
Try a mass compile. If add-ons or toolkits have not been resaved for LV 8.5, the asterisk maybe right.
You aren't using XControls or LVOOP are you?
Ben
05-13-2008 09:32 AM
Thanks for your input. I don't know what you mean by a "mass compile". I've build my application - both a stand-alone exe and the installer (and it works), and I've saved the project. Then when I re-open it I get the asterisk. I can save it again, but the same thing occurs when I open it again.
No, I'm not using XControls or LVLOOP (whatever they are). Also, the application was developed originally in version 8.2.1 and then saved in version 8.5 when it became available. Everything else works fine, the same as it did in the previous version. This is the only difference I've seen.
05-13-2008 09:38 AM
05-13-2008 10:00 AM - edited 05-13-2008 10:09 AM
Ok. In my dependencies list of my project file, I have about half a dozen or so vi's from version 8.2 (in various subfolders of C:\Program Files\National Instruments\LabVIEW 8.2\examples). Those vi's must be the culprits. Correct?
I think it might be best for me to save each one individually "as" version 8.5 in the 8.5 directory. Or better yet, "replace" them with the 8.5 version, assuming they all exist. Correct?
05-13-2008 10:05 AM
05-13-2008 10:08 AM
