Events between 2 Event structures & Queues.
Hi Everyone,
Attached you'll find a example of Two event structures inside while loops.
The bottom loop is paused or release by a queue.
I don't understand why the play event is not registered on the bottom loop the first time it is fired.
any idea?
Thanks a lot,
Best Regards,
(3,119 Views)
I think the problem is how you're using the Dequeue in the bottom loop - it's waiting for a value from the Boolean queue before the event structure has registered for the User Event for the first time - therefore that first event gets lost.
(3,113 Views)
Hi Greg,
Thanks for your answer, I understand that but is there a workaround?
How should I do to make sure I register the first event?
Also, is there a way to check timing on events and queues, for example how can I know that an event has been registered on a register event vi?
(3,088 Views)
Accepted by topic author Olivioloyer
Thanks You were perfectly right I just inverted the order of execution with the error wire and it works great,
(3,068 Views)
