Event in 1st "While Loop" must stop 2nd "While Loop"
Not-keeping default values issues resolved: I had been mistaken - being in harry, instead of save as default values I made "default types".
But neverteless even I restart VI, the old values for frequency and amplitude still remain.
Does exist something like TOTAL RESET of VI.
Thanks.
Message 11 of 24
(2,208 Views)
Is its either:
"right-click...data operations...make current values default"
or
"select control...menu...edit...make selected values default"
What do you mean by "total reset of VI"?
You can do "menu...edit...reinitialize values to default", but that won't clear uninitialized shift registers or chart histories. You can also do it programmatically with an invoke node.  If you have done some editing, you can do "menu...file...revert".
Why don't you attach your code?
Message 12 of 24
(2,192 Views)
Unfortunately I can't test your suggestions because already at home and have no access to device ... will try it tomorrow.
But I kept the code (in attachment).
By "total reset" I mean some action the put VI in a state as if it was just created (just before 1st run) ... all buffers are empty, all variables are at theirs initial states, etc.
Because what I observed make me think that some history traces are active and influence the VI behavior.
Thanks in advance.
Message 13 of 24
(2,171 Views)
Message 14 of 24
(2,148 Views)
Because a property node runs about 100 times slower than a local variable.
If you don't need the features of having the error wire, or havint the ability to programmatically select the control reference that the property node applies to, then there are no advantages to the value property node and only disadvantages.
The second part of what you say "
Message 15 of 24
(2,141 Views)
Indeed I know about what you told but I don think that they make problem in such condition but your text was really complete and helpful about it
thank you for that
Message 16 of 24
(2,130 Views)
Dynamic Events, Queues, Notifiers, FGVs are examples of design patterns to stop multiple loops in parallels and to be sure to avoid race conditions (well .. almost ..). LV Core 2 taught you some of these, have a look at it.
Certified LabVIEW Architect (CLA)
Message 17 of 24
(2,109 Views)
Pavel_47: How are you stopping your vi?
You have a loop that can never be stopped, due to the False constant that you have wired to the Conditional stop terminal.
If you use the Abort button, then stop doing that now. Your DAQ clean up code will never run, that the DAQ tasks will never stop.
Check your error wires for any errors in the system.
Message 18 of 24
(2,093 Views)
Hello A
Message 19 of 24
(2,090 Views)
Hello Dkfire,
It looks like cycle of 2 steps:
I start VI and it stops itself
Then I restart it, nothing happens and I click on "Abort Execution"
Then this 2-step behavior repeat.
But what is surprising - this morning I run the VI after powering both - USB-6343 and PC with LabVIEW ... and it still started with amplitude/frequency that I saved as default YESTERDAY.
Concerning errors ... I have 2 error paths on generating and acquiring - nothing happens (at least no error message appear)
Message 20 of 24
(2,081 Views)
