Showing results forĀ
Search instead forĀ
Did you mean:Ā
Event Structure
Hi Bob_Schor
please give me a day, I have informed my PM. I have already made a stripped down version which will give you the idea of what I am trying to do. Once he confirms I will upload it. I am also eager to upload it. Its a very simple VI, still error.
Message 11 of 15
(1,624 Views)
I have attached the ripped off version.
the VI is supposed to do the following
1.select a mode
2.make your changes
3.load
4.again 1
5. stop when you want
Message 12 of 15
(1,592 Views)
Hi balanunni,
unfortunately you attached a LV2014 project which includes some LV2015 VIs.
Could you provide all of the content for LV2014?
Message 13 of 15
(1,590 Views)
converted whole project for LV14
Message 14 of 15
(1,583 Views)
Accepted by topic author balanunni
Plz find the attached picture. In the picture event is created dynamically and closed after exit. This is a workaround.
I would prefer to keep both event structure in one, because if you make event structure for different states in the same block diagram, that leads to problems. So it is preferable to keep one event structure for one VI.
Message 15 of 15
(1,580 Views)
