Event Structure on Myrio
I am using event structure from LABVIEW but to load the file on Myrio, the file does not work
(5,627 Views)
Event structures dont fully work on real time targets because the front panel executes on the host while the block diagram executes on the real time system.
Cheers
(5,625 Views)
how i can do work a event structure on myrio?
(5,354 Views)
Can you be more specific on what you are trying to do?
(5,350 Views)
I'm trying to use an event structure with a myRIO which is connected via wifi to my computer. When i run the program the myRIO does not accept any event.
(5,336 Views)
The Event Structure does not work on embedded systems (except for the cRIO-903X series).  Furthermore, you need to develop your myRIO to be able to run without the LabVIEW IDE.  What you need to do is create a Windows application that can communicate with the myRIO over TCP/IP.
(5,331 Views)
