Event Programming - Really Basic question
Jup .. actually I am working under 8.0.1
Somehow I already had that one in mind (I'm not new to programming, and design patterns usually don't change a lot 😉 ) but somehow your explanation sounded much more complicated (probably my english skills aren't that good) 😉
I'll look into this. Thanks
Message 11 of 23
(2,531 Views)
Unfortunately I'm not a teacher but just a software developer, working in the dark corner of an office ;).
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 12 of 23
(2,529 Views)
Well. 35°C outside. Large Window. Can't tell it's dark in here Smiley Very Happy
Message 13 of 23
(2,526 Views)
I think we are a little bit below - 32°. But still far to hot. I closed the shutter when I started to work 6.5h ago. Everytime I get out of the building after work (Yeah - just 2.5hrs to go :D) I almost go blind ;).
Using LV8.0
Message 14 of 23
(2,525 Views)
Too hot? The hotter, the better.
AC does it's job perfectly 🙂
One last question: Do you know of any good books. I have one here (Pearson Studium, Labview for Students) - but it's only a larger Help file. It doesn't really explain the things I'm interested in 😞
Message 15 of 23
(2,523 Views)
AC? Never heard of AC - must be some new invention. Or at least it does not have come to us yet ;).
No, I don't know of any good books. I know there are some thread that at least contain links - just search. Or maybe you could open a new thread on that.
Thomas
Using LV8.0
Message 16 of 23
(2,521 Views)
Hah .. Now I got another, maybe better example.
Imagine some application. It contains a table. I can load data from a Xml File, to that table, edit it there and then save it back to the Xml File.
How would I do that without using property nodes? I need both - read and write - to the table.
Sorry, this is really my last question 🙂
Message 17 of 23
(2,518 Views)
Local variables...
Using LV8.0
Message 18 of 23
(2,515 Views)
And don't mind to ask more questions. That's why we all are in here - ask question and answer questions.
Using LV8.0
Message 19 of 23
(2,514 Views)
Well .. it's just - I hate being unable to contribute.
I am a member of some other forums, where I can at least give good advice as well as asking for it, but here - it's more getting than giving.
Thanks for your help
Message 20 of 23
(2,511 Views)
