Even Parity Resultant from a Long String
Accepted by topic author neunited
neunited wrote:
Even parity check resultant is coming out as B, but actually it should be 0B. So I thought the "00" would do the trick but unfortunately it still comes out as B at the moment. This is important because the hex of B is 42 and hec of 0B is 3042.
On the Number To Hexidecimal String, there is an input for the width of the string output.  Set that to 2.
Message 11 of 12
(506 Views)
Spot on! Thank you
Message 12 of 12
(502 Views)
