01-23-2020 05:42 AM
Hello
How can I send an exact plot to the function EthernetIP CIP Set Attribute Single VI?
01-23-2020 07:31 AM
You might need to explain a bit about the context.
Exact plot of what?
What function is "EthernetIP CIP Set Attribute Single VI"? Probably from a toolkit? Which one?
01-23-2020 08:14 AM
Sorry, I am going to try to explain it better.
I have the program attached bellow. I want to sent a plot in "data to set" of 0 2 0 0 0 0 0 0.... and I want to check in " data received" if the plot that I sent is correct.
I hope I explained myself better.
01-23-2020 08:31 AM - edited 01-23-2020 08:33 AM
Hi 99,
which device are your communicating with?
Why do you need to use these messaging functions?
What is the problem with your VI? Do you get any errors? (There is no error handling, not even a error cluster to show errors…)
Just write these data in the "data to set" array…
01-23-2020 09:29 AM
That sub VI (that is missing) has a resource in and out.
This usually means you have to initialize the resource (once) then do use it (in a loop) then close it.
It's still not clear what this sub VI does, what it should do and where it comes from...
Using the sub VI in parallel might or might not be allowed.
01-23-2020 10:03 AM - edited 01-23-2020 10:03 AM
Judging by your rather vague description I am guessing you want to send some data (looks like an array of integers) to another computer on a LAN and have the receiver acknowledged the data sent?
Open up the LabVIEW Help and search for examples using TCP as the search term and look at the "Simple TCP." example
Then come back when you have questions
01-23-2020 07:05 PM
Ethernet IP is ODVA CIP object model over ethernet, its a lot like devicenet but over ethernet rather than CAN.
I have done a fair bit with ethernetIP in the past, but sadly I don't understand the question.
Likely it relates the the NI ethernetIP toolkit. It used to be an NI labs thing back in the day, but think its a paid addon these days.
01-24-2020 04:30 AM
I am communicating with the JXC91 and I am trying to send a signal to energize the cylinder.
Then I want to check if the signal corresponding to when you energize the cylinder has been activated
02-03-2020 07:05 AM
I am trying to connect with a cylinder with ethernet from labview and I have got it because I have done different functions where I have probed that this connection is good. Now, I am doing a different function and I have found this error and I don´t understand why it apperas.
I attach also the program
