EtherCAT slave not showing user defined channels in LabVIEW
Hi all,
I'm facing a problem while connecting one of the EtherCAT slaves in my LabVIEW project.
I have LabVIEW Real TIme Target NI PXIe 8135 and EtherCAT Master NI8234.
I have already connected the EtherCAT Master to the LabVIEW project and also added 3 slaves to it.
Now i am facing problem while adding the 4th slave which is Beckhoff EtherCAT Terminal EL 6695.
Shown below is my labview project.
Here, the issue is, I have some user defined channels already defined on this EL 6695 slave.
But as you can see in the image only the vendor provided 3 default channels can be seen. All the user defined channels are missing.
A probable reason behind this could be that I have imported the vendor provided 'device description XML' for this slave EL 6695.
May be I should provide a modified device description XML file which will cater for my user defined IO expansion.
Looking forward to your expert comments!
Thanks in advance!
Rahul.
Germany
Message 1 of 1
(3,122 Views)
