Establishing Communication Between Aglient DMM and LabVIEW
I am attempting to collect data from an Agilent 34401A DMM using LabVIEW, but have been unsuccessful in my attempt to communicate with the device from LabVIEW. I have installed the proper device driver and I am using a USB-488 GPIB to USB converter (I have also installed proper drivers for this device). LabVIEW does not even recognize the device despite the presence of the proper drivers. How do I establish communication with the DMM from LabVIEW?
Message 1 of 11
(4,413 Views)
Is the usb-gpib converter from NI? If it is, what version of NI-488/NI-VISA did you install for what os? Before messing around with LabVIEW, did you check if it's detected in MAX?
Message 2 of 11
(4,412 Views)
You have to enable the "Tulip Driver" in NI-MAX to get it to be recognised.
I am not sayin' it's a conspiracy, but you will notice the the Tulip Driver is the only driver that is not enabled by default. Smiley Wink
=== Engineer Ambiguously ===
Message 3 of 11
(4,401 Views)
The converter is from Measurement Computing and I installed the NI 488.2 for Windows XP. I am unsure what MAX is.
Message 4 of 11
(4,399 Views)
NI 488.2 and Ni-VISA should have installed teh Mesurment and Automation eXlplorer (NI-MAX)
Deep in the 488.2 settings of NI-MAX there is a set of drivers that can be enabled, make sure the Tulip Driver is enabled because it is not be default.
Message 5 of 11
(4,392 Views)
@Soph wrote:
The converter is from Measurement Computer and I installed the NI 488.2 for Windows XP. I am unsure what MAX is.
MAX stands for Measurement and Automation eXplorer.  If is a program that NI has so that you can look at what instruments are detected and create interfaces for them.  If you don't have that installed, then you probably don't have VISA either.
I've never heard of Measurement Computer.  Does Windows detect the device?  Do you have some sort of test interface you can communicate through?
Message 6 of 11
(4,390 Views)
MAX is short for Measurement and Automation Explorer. It is a utility program from NI. Installed with their drivers.
You need to check with measurement computing for instructions on how to get it to work. Enabling tulip support might be enough. Not many people use anything other than NI (some agilent).
Seems silly to install an NI driver for a third-party card. Where did you get the instructions to do that?
In order to use the driver for the instrument, you must install VISA.
Message 7 of 11
(4,385 Views)
Measurement Computer (MCC) is a DAQ manufacturer which NI bought several years ago. It continuues to operate under its own name. I do not know whether MAX can see their devices now that they are a cousin to NI.
Lynn
Message 8 of 11
(4,380 Views)
Okay my bad, you need to install NI-VISA and it should also install NI-MAX
In NI-MAX under Tools-->Ni VISA-->VISA Options
Will bring up this screen, select Passports under General Settings.
Make sure the Tulip Passort is enabled, as you can see it is not enabled by default.
Then plug in and rescan for instruments in NI-MAX and it should see your USB-GPIB.
If not then you might want to contact Mesurment Computing as they say it is Labview compatable
Message 9 of 11
(4,331 Views)
I have enabled the Tulip Passport and the USB-GPIB is still not detected in MAX. What type of connector is typically used when collecting data from a DMM using LabVIEW?
Message 10 of 11
(4,292 Views)
