Error with NI_Excel.lvclass
i must modify a program build with lv2014, 4 years ago from a colleague no longer disposable.
As soon as i have open the project i have failures. screen shot with first listed failure attached.
I can not interpret the failure message.
Anyone can help?
(2,522 Views)
Accepted by topic author SeppR
Hi Sepp,
While the source code of your program did not change in the last 4 years most probably MSOffice changed (a lot) in that time!
That's why you get the error message: "Methodenknoten: Funktion enthält einen unverbundenen oder fehlerhaften Anschluss" ("Method node: function contains an unwired or erranous connection"): This specific Excel method may have changed in those years and most probably contains new/more parameters!
To solve this issue:
  • Click on "Replace" in the method title and select a different method, then select "Replace" again. Some new parameter(s) will appear in the method node.
  • Read the help for that method in Microsofts Excel help (found at MSDN) to learn about the significance of those new parameter(s)…
(2,519 Views)
Hi Gerd,
issue solved 🙂
(2,497 Views)
