Error with NI_Excel.lvclass
i must modify a program build with lv2014, 4 years ago from a colleague no longer disposable.
As soon as i have open the project i have failures. screen shot with first listed failure attached.
I can not interpret the failure message.
Anyone can help?
(2,541 Views)
Accepted by SeppR
Hi Sepp,
While the source code of your program did not change in the last 4 years most probably MSOffice changed (a lot) in that time!
That's why you get the error message: "Methodenknoten: Funktion enthält einen unverbundenen oder fehlerhaften Anschluss" ("Method node: function contains an unwired or erranous connection"): This specific Excel method may have changed in those years and most probably contains new/more parameters!
To solve this issue:
  • Click on "Replace" in the method title and select a different method, then select "Replace" again. Some new parameter(s) will appear in the method node.
  • Read the help for that method in Microsofts Excel help (found at MSDN) to learn about the significance of those new parameter(s)…
(2,538 Views)
Hi Gerd,
issue solved 🙂
(2,516 Views)
