Error while install labview in linux ubuntu
I was installing LAB VIEW 2022 SP1 in my virtual environment of Linux Ubuntu. Downloaded ISO file from lab view platform and mount it then run the terminal command but this happened.
(1,431 Views)
Accepted by Hussain_Ali
You need to first navigate (cd, change directory) to the directory of the installer in which the install script resides. Then only you can run the install script.
See Install LabVIEW on Linux Operating Systems
https://tmesystems.net/
(1,428 Views)
