Showing results forĀ
Search instead forĀ
Did you mean:Ā
Error when trying to set up OPC I/O server with LabView 2009
Hi.I get an error when I try to set up OPC I/O server with LabView 2009 and the DSC module. If I open an empty project, right click ā€My Computerā€. Select new / I/O Server… and then OPC Client, the following error appears: Unable to browse OPC Server from the selected machine.Error -2147467262 occurred at GetOPCServerList.viPossible reason(s):LabVIEW: (Hex 0x80004002) No such interface supported.
I have tried to repair LabView, but with no luck. Any idea what it could be?
(3,999 Views)
This should help [broken link removed]
(3,988 Views)
Hi muks and thanks for your reply.
I have actually found that post and already tried that solution.
It didn’t help me šŸ˜ž
(3,984 Views)
You have posted here too. Should we continue there?
(3,981 Views)
These are two separate issuers.
The post you refer to is a problem that I have struggled with for a long time using OPC with DCOM.
This post refers to a problem I got after upgraded to LabView 2009 on one specific computer.
The problems are not related to each other.
(3,977 Views)
Ok then. Lets try getting this solved. Lemme dig......:smileyhappy:
(3,975 Views)
