Error when calling a Dll with point
Hi there,  I try to call  function with below function, somehow it doesn't work well.
I enclose vi in attachment, please check if any wrong when I create it, thanks in advance.
Function source:
MXEIO_Connect(
char * szIP,
WORD wPort,
DWORD dwTimeOut,
int * hConnection );
Did I put wrong format in handle "hConnection"? I set it as a format " point" ,  return value, however, is still wrong .
(3,338 Views)
Try "Signed Pointer-sized Integer" for data type.
George Zou
(3,325 Views)
Thank you for your advice, I follow the change you advice and it doesn't work
the original function like below
MXEIO_E1K_tpfConnect(char *, WORD, DWORD, int *, char *);
(3,282 Views)
Looks like you forgot the last parameter: char *
George Zou
(3,278 Views)
Because vi wrap a shell around the funtion with char.
I update VI according to original funtion, pls help to check, thanks
(3,275 Views)
What?
Is the last parameter (password) an input ?
An empty password ?
You didn't provide enough info to determind if the calling convention should be stdcall or C.  Can you post the header file?
George Zou
(3,246 Views)
